How to connect 2 Soundcore Boost to play at the same time?
I have 2 Boosts, one is Old and the other is Upgraded version. I can connect them simultaneously to play songs on my phone but the problem is, they are out of sync and they make a “theater effect” if you know what I mean. However, the last time I tried they were sync, and now I can’t figure out how to sync them again.
Video coming.
May be you should do a reset on both sspeakers and reconnect.
Hey @ndkhoa5
I have the old Boost and live it.
The old and new Boost can’t be “linked/paired together” so if you managed to get sound from two Boosts at the same time time it must have been down to the device/source.
So I can only guess that’s the root of the problem.
Could be sequence in which your paired them, perhaps newest to phone, oldest to newest?
