Beforehand I want to mention that I have tried charging both the case and earbuds before now along with a couple dozen resets in an attempt to fix this issue. There is no physical damage or exposure to water and this issue started very suddenly while in use.
My right earbud refuses to turn on and my left refuses to attempt to pair. My right earbud shows it is charging and when this happened it was at 50% battery. A loud noise cut off my music and then the device powered off. I turned it back on and had to re-pair the device. It worked again until 5 minutes later the same thing happens. After I reset the device a second time the led indicator on my right earbud stopped turning on. Unless it was charging. My left turns on but does not attempt to pair on its own. Both earbuds charge as normal. Is it possible to fix this issue?
