Got myself a Homebase and two eufycams last week and after making sure I could reach all planned locations, I ordered another two cams. This is my experience after using this set a week.
- Installation was a breeze. Homebase had to update, which was shown in the app. After connecting cam1 I thought the installation failed untill I discovered that the cam was also updating. Suggestion: make that (more) clear in the app;
- Signal reach is barely sufficient. I have a recently build house and one wall will effectively reduce the signal by one or two stripes. Two walls is not usable. I placed the homebase in a shed build against my home using wifi connection and that works because of the thinner walls. I ended up with one cam having full stripes, two cams with 3 stripes and one with two;
- I’m really happy with the user interface of the app. All self explaining;
- Had to play with the Activity Zones of one cam to avoid false triggers by some branches with leaves. Now that works fine;
So overall I’m a happy user so far
