Finally a PD PowerCore+!
yeah, it seems to be gone from the anker website. Just wondering. O.O
Don’t read too much into it. Items disappear and reappear all the time.
Powercore+ 26800 w/PD can charge iPad 12.9 really fast! iPad gets a little warm though. Best portable charger I have.it recharged fast also.
Apple charges $50 for 29w charger this pd batt. Includes charger for free!
How fast? From what % to what % in what time.
Anker claims 2 hours.
Well the 12.9 is a 38.8Wh battery so a 29W should do it in about 1.7hr (0-85% is 33Wh so should be in 1.13hr at 90% efficiency then half the speed 85%-100% 38.8*.15/29*2/.9 = 0.45h so total of 1.7h
So to take 2hr seems a little shabby. That implies more throttling earlier than 85%?
Yep. Throttling starts at 80
I’m no electrical engineer,but i know pd 26800 will charge 2017 iPad 12.9 faster than included 12w charger.that comes with iPad.
Yes because 29 > 12
It is not electrical engineering. The ipad is capable of ingesting at 29W, so a 29W will be faster than a 12W.
Pd 26800 seems to charge iPad as fast or faster than oem 29w.
Tim Cook says iPad Pro can fast charge at keynote, Apple Store employee tells me NO ! Says it will shorten batt. Life and use between charges. Will pd 30w shorten lifespan on iPad ?
@nigelhealy Would know more about that than myself.
Also the PowerCore PD is capable of only 27W, not 29
It depends on what Apple decided was the thermal throttling temperature during recharge. If they had chosen to set it higher then you’d get faster recharge time but the battery would age faster.
http://www.batteries2020.eu/publications/201509EPE15/Ageing.pdf
But I suspect that temperature effect is secondary to the human factors dimension. If:
  • someone thought “oh i own this really fast recharging battery”
  • therefore did “i now can use my ipad til its nearly flat because I know I can recharge it fast”
  • then you’d be causing deep cycles which ages batteries even faster than the effect of temperature.
So ironically it might be you the owner causing the problem with how you behave due to having this technology rather than the technology itself.
So recommendations:
  • keep liberally attached to power as much as is sensible to reduce depth of discharge. If you think "because i can I will’ on using unplugged from power a long time you are via that thinking aging the battery faster.
  • the heat by-product of recharging ages the battery, the heat by-product of using the tablet whilst recharging compounds it, so if you did happen to require to use the ipad unplugged from power for a long time, then consider not using the ipad whilst recharging.
  • the more you use a battery the faster it ages, so just keep near power as much as practical.
  • you have paid a lot of $ for the ipad so use it! Just try to use it’s unplugged from power use to a sensible limit related to need, because if you keep it unplugged and use it a long time more than you need to then it will age faster.
  • consider turning it off before doing a full recharge from empty to full, so the heat from the CPU is removed. It will likely recharge faster as well as age slower.
Thanx for the useful info!
Which would hurt recharge times more:
Display on (25% brightness, airplane mode, not doing anything)
Display off (airplane mode off, notifications)
So firstly, you’d be far better off in controlled measured situations because then you’d know rather than guess.
There are multiple sensors throughout a modern device, in the GPU, CPU, charging cuircuit and sensing the battery. These are spread around the device in a specific layout for each device. There will be an algorithm which directs recharge speed based on these sensors.
So i cannot predict between those two options their impact. If you gave a 3rd choice which is power the unit off so there is no cpu and no gpu heat output then it would have faster recharges.
I agree that the Powercore 26800 PD is a good product in the context of the ~30W region.
It is going to be comparable in performance to a ~30W charger and so in such a context will be impressive to those with that Wattage scope.
The concerns are:
  • it is expensive (for no underlying good reason - competition?)
  • lower Wh products with higher Wattage. Currently QC is disproportionately benefiting and relatively little for USB-PD
  • The 100Wh TSA / FCC / CAA common upper limit is probably able to make a 60W USB-PD product
  • Above the 100Wh limit there is scope for USB-PD output products in the area of successor to Powerhouse. The use of DC-AC-DC of the current Powerhouse is less efficient than a DC-DC USB-PD output.
In my personal situation I am currently parked in use of Chromebook with the 19V non-USB for home use and a 15W USB-C for traveling, and I’m waiting for the USB-PD ecosystem to be better served. I am waiting for USB-PD multi-port chargers and USB-PD portable chargers to develop into a better ecosystem so I can then merge my devices into a common USB-PD standard, which will lower physical size and costs.
