@AnkerSupport thank you for replying swiftly.
I have the Homebase 2 cause that is sold together with Eufycam 2 and the wireless doorbell. There is no option to buy Homebase 1 with either the wireless doorbell or Eufycam 2.
From your question on which Homebase version I have, I conclude that there should be a choice when buying the wireless doorbell or Eufycam 2. Is that so?
I’m surprised and disappointed that this isn’t more clearly mentioned. The information in the App suggests that face recognition is available but nowhere it is mentioned that this requires Homebase 1.
So Homebase 2 isn’t a true successor to Homebase 1.
If I could buy a separate Homebase 1 (which I can’t cause it isn’t offered as a standalone product) would this be supported in the future?
Will there be AI support in future Homebase versions?
Brgds,
Eduard
