Extremely disappointed
I was an original investor in eufy cameras. I bought a large package and installed everything in November 2018. Since then I’ve had two cameras fail. They cannot be recharged or repaired. They are not covered under warranty. I think, for what they cost, a camera should last more than 3 1/2 years. Not sure whether I’ll continue to invest in their products or move in another direction. I’m just very disappointed.
Have you been in contact with EUFY?
Have you published your disappointment at EUFY’s forum?
@Chiquinho I think you are having my problem… duplicate postings
@Himrich, They have the same warranty as most other but I do concur on that it should be lasting longer. I think that I would try what @Chiquinho has stated depending on when the camera when out of warranty. If it is close, I think they may work with you. I know others have stated a few times that they did get some help from it. If the failing was like several years ago then I think you may be out of luck.
Contact support and explain what happened. Maybe you can reach a satisfactory solution
