Eufycam 'original' homebase with eufycam E
Hello,
Building on another thread - can I use a eufycam E cam with my ‘original’ eufycam AI homebase?
Thanks!
Yes the homebases can pair with either camera
Both cameras have pretty much the same spec (water & dust resistants rating being the only difference)
The main differences is in the homebase
Homebase has battery backup & AI
Homebase E doesn’t
I personally prefer the bullet look over the cartridge look
@Haloweenhamster is completely correct.
This, and the original eufycam has a better IP rating.
This, and this :wink:
png%20%20WEBP%20Grafik%20%20700%C2%A0%C3%97%C2%A0319%20Pixel%20
Yes. The homebase is what provides the AI (camera sents footage to homebase, homebase processes it) functionality. There are some slight differences between the cameras though besides looks.
