Eufy Smart Switch Connection trouble
I have installed my new Eufy Smart Switch, but it will not connect to my wifi. The front shows a solid white light (instead of the blue and amber flashing ones that are supposed to be there). Any suggestions on what I can do?
You need to be relatively close to the switch during setup.
Hold down the reset button to get it to flash blue and Amber.
Let me know if you have any other questions I’m happy to help.
