eufy [BoostIQ] RoboVac 30C, Robot Vacuum Cleaner Is on a deal for $199
Use the code EUFYROB30C for $80 off + plus Amazon coupon for $20
Product description
RoboVac 30C
The Super-Slim and Even More Powerful RoboVac with Wi-Fi Connectivity
Lean, Mean, Cleaning Machine
RoboVac may be super-slim, but it’s packed with a 3-point cleaning system, BoostIQ technology, and up to 1500Pa of suction power to ensure your floors and carpets are clear of all dirt, dust, and crumbs. And with Wi-Fi built-in, you can accomplish all your cleaning needs from your smartphone.
Eliminate Vacuuming Chores
RoboVac takes on dust-busting around your home so you don’t have to. Multiple cleaning modes and auto-clean scheduling ensure an effortless, thorough clean while you relax.
Improved Cleaning
Refined from the inside and out to provide quiet vacuuming with zero hassle, RoboVac cleans with the equivalent sound of an operating microwave.
Cleans Further
A larger 0.6L dustbin allows RoboVac to pick up more dirt and dust to take full advantage of 100 minutes** of continuous cleaning, eliminating the need to empty it halfway through cleaning.
For Optimal Use:
Use on low- to medium-pile carpets, tile, laminate, and hardwood floors. Not suitable for high-pile carpet.
Move cables out of the way to avoid entanglement. 5 cable ties are provided in the package to help you better organize wires and power cords.
Note:
*Maximum
**Standard suction mode (hardwood floors) provides approx. 100 minutes of cleaning. BoostIQ mode (carpeting) provides approximately 50 minutes of cleaning. Max suction mode on medium-pile carpets provides approx. 40 minutes of cleaning.
RoboVac only connects to the 2.4GHz frequency. Make sure you are using a 2.4GHz router or a dual-band router that is configured to support a 2.4GHz frequency band. RoboVac does not support 5GHz frequency band.
3-Point Cleaning System
Three brushes and strong suction power effectively loosen, extract, and vacuum dirt to give a superior clean.
Pure Power Puck
RoboVac 30C sucks up dirt and dust with 1500Pa of suction for a spotless clean you can see and feel.
Non-Stop Cleaning
Large wheels roll over carpets and climb over door ledges to get to the mess.
Endurance Cleaning
RoboVac cleans up to 100 mins* per charge, so you get to enjoy a completely clean home from a single charge.
Zero Attention Needed
RoboVac uses drop-sensing technology to avoid falling down stairs and off of ledges.
Stays Within Borders
Specialized dual-Hall Sensors detect Boundary Strips to ensure RoboVac only cleans the areas you want.
Automatic Cleaning
9 anti-collision infrared sensors helps RoboVac to avoid bumping into obstacles so it can clean non-stop without help from you.
A Quiet Clean
Advanced brushless motor significantly reduces vacuuming noise.
