eufy Lumi Stick-On Night Light available now for $11.99 on a Price drop
Eufy Lumi Stick-On Night Light price drop - $11.99
Your friend Watson has such ones.
They are enlighten him a lot!
I can totally recommend.
Great little torches.
Great little lights in the dark and great offer. Thanks for sharing
I might get a couple for my nieces
These are really good to use at home, usually if you have guests at home, these are the best To help guests try to.navigate at night before they hit light switch
Do you own any of them?
If you have a “dark toilet” in your house it helps a lot if you are in hurry!
I own some of these, spread all over the house
Very, very useful.
Great, I’ll definitely get some for my nieces them
I bought a set sometime back.based on feedback from our known Community members … been working well
That’s great, I’m sure they will like it
Nice deal!
Does anyone have the 1st and 2nd generation?
I’m tempted to get a pack but interested to know if the high or low brightness on the 2nd generation is the same as the 1st generation.
I know I should get the latest but 1st gen is cheaper than the 2nd gen.
I own some of the 1. generation.
Those are a great orientation guide.
You should not expect a huge illumination they are not designed for this.
If you need such there are others on the market.
Thanks.
I was trying to work out whether to spend the additional money on the 2nd generation.
I think I’ll just order some 2nd gen tonight and have a play.
yes, have a set of these, bought earlier this year… happy with them!
Thank for your feedback @Chiquinho and @Shenoy
I’ve placed my order for the 2nd gen.
I’ll do a review soon.
Hope you like them and look forward to the review when you get those
Before glueing and screwing, try different positions.
Best is not to glue and not to screw.
I put some of mine on top of the door frame.
Good illumination from there
glad you put illumination in there, else the words are
