As backchecking i have another sugesstion regarding this improvement!
As you know i am using this sensor to track how often and how long the main entrance to my house is opened. As you also can see, as an example, i just had a very long time where the main entrance door has been open, as one of my new tenant forgot during movement to close the door again after unloading his car.
@AnkerSupport @AnkerTechnical @AnkerOfficial
So my regarding suggestion:
Could you please add, beside the suggestion above and the reason for this thread, an OPTION where i could set a freely definable time limit between 1 and xx minutes, after which i would get a push notification?!
Like:
âATTENTION: Entry Sensor âHoftorâ detected that it is still open after [xx] minutes!â
So if one of my visitors or tenants (or even myself) forgot to close the door after, for example, 30 minutes, i would get push informed and warned to be able to check if everthing is fine and door still needs to be open or not, so i could close it.
Thanks!
