All of a sudden, when I ring the Eufy wireless doorbell with my mechanical chime, it causes it to ding first, then makes the plunger vibrate back and forth for about two seconds (making a loud vibrating sound), then finally doing the song after doing just one short press with the doorbell. How can I tell it to send just one short signal, instead of this long one? It didn’t used to when I first installed it the other day.
Here is a video with audio demonstrating the issue: https://imgur.com/a/db6HG3L
I should note that if I select the mechanical chime again in the setup, it works just fine again. I just want to fix this once and for all instead of setting up the chime again every few days indefinitely.
