Eufy Doorbell on Echo Show
I did not do anything special to turn on the custom option. My Alexa app version on the iPad is 2.2.389238. I’m located is the USA
I would also like to get this working and willing to buy echo show just for this purpose. Can anyone tell me how long the delay is from pressing the bell to the video showing on the display.
I wouldn’t even need this if the eufy app had the option of live feed when the bell is pressed rather than having to click the notification.
It take 3 -4 seconds for me. - Sometimes.
Or else I get the screen trying to connect to eufy app, and no connection at all.
The person ringing to doorbell have gone by then.
It only works for video and one way sound. I can’t talk and answer the doorbell with Alexa
Are you saying the person ring the bell can here you? I can only see the video and hear sound but cannot answer back through Echo show
No Problem setting up Custom Routine Action to show the Doorbell on a single Alexa Device (this part is frustrating - you can only select ONE device from the available options for the Routine)
However I’ve added additional routines exactly the same but just changing the display device in the action and that works.
i.e. one routine for show 8, one for show 5, one for Fire HD10 etc so now display comes up on Multiple devices.
*My one question is how to limit this by time? For example if not home, don’t want these to come up and remain on live video all day - would like to display for say 30-45 seconds then turn off. Any idea how to do this?
*Edit - OK figured that part out too. Create another routine triggered by the doorbell press - this time for action first wait for (whatever time you want display to be active) then custom again and ‘Hide Doorbell’ from selected device. Again you only get one device so will need a separate routine to hide for each device you created to display
Routine
Name: Show Doorbell on KItchen Show
When: Doorbell is Pressed
Add Action: Alexa, Show the Doorbell (from Custom)
AND
Routine
Name: Hide Doorbell on KItchen Show
Add Action: Wait 45 secs (or whatever time you want to keep display alive)
+Alexa, Hide the Doorbell (from Custom)
and repeat BOTH for additional display devices you may wish to also utilize.
Can any body tell me if you can get a live feed on amazon show 8 when eufy security doorbell has been pressed UK ?
try the Eufy community
Just a quick update on this topic. I used Eufy Cams 2 Pro with a Homebase 2 and had some issues connecting the live stream via my Echo Show 10 or Echo Show 15. Lately i updated to S330 cameras and a Homebase 3 and now the live streaming works very smoothly. I can only assume that the updated hardware provides the neccessary power to processe the livestream fast.
