Amazon has Eufy Baby Monitor w/ 720p HD Resolution & 5 inch LCD Display for $109.99.
Clip the $30 discount from Amazon
Use the Code BBMHHH22 for $20 off
Total $50 off !!!
From the manufacturer
#### Double Your Field of View |
Simply attach the included lens to expand the view to 110° for a full view of the nursery.|#### Wall Mount Included
Set SpaceView wherever you want to get the view of your baby - even on a wall.|#### Nighttime Video
When it’s time for bedtime, night vision technology continues to monitor so you can get your zzzzz’s.|#### Zero Set Up Required
Because no set up of any kind is necessary, SpaceView is ready to use right out of the box.|
#### Know When You’re Needed |
You’re only notified when SpaceView detects the ambient noise to be louder than what you set and when your attention is needed.|#### Built-In Thermostat
See what the temperature of the nursery is in real-time throughout the day.|#### Real-Time Communication
The built-in microphone and speaker give you direct communication to your baby, even if you’re elsewhere in the home.|#### All-Day Usage
The high-capacity 2900mAh rechargeable battery provides a full-day of monitoring.|
Product description
Style: Baby monitor
SpaceView Baby Monitor
The Pioneering In-Home Baby Monitor with 5’’ LCD Display.
See The Bigger Picture
Packed with 10 times more detail than standard 240p baby monitors, SpaceView’s large 5’’ HD resolution display shows a bright, crisp and clear picture. When the lights are out, night vision technology provides clear video so you can rest easily.
See Close, See Wide
Change the focus of your SpaceView camera—from a close up of your baby to an expansive view of the nursery—in an instant by attaching the included wide-angle lens.
Set and Forget
SpaceView pans 330° to see corner-to corner and tilts 110° to see from floor to ceiling, giving you a good angle of your baby wherever you place the camera. Instant Noise Alerts You’ll receive an alert on the monitor immediately if the ambient noise exceeds the limit you set.
Always By Your Baby’s Side
Built with two-way audio and a full 460 ft of coverage range, you can see and hear everything in real-time, even from your backyard.
