I recently bought a Anker PowerCore+ 20100 USB-C, Ultra-High Capacity Premium Portable Charger to charge the Nintendo Switch.
Does the usb c charging cables that came with this charger have 56k ohm resistor in them?
the cable that comes with that power pack is a USB-C to USB-C cable so there is no need for it to have that 56k resistor. the resistor is only needed when you are using a usb a to usb c cable. so if you are worried about fast charging and current possibly ruining your device then you should be fine provided you use the included usb-c to usb-c cable.
