Different settings per Motion Detection Zones
It would be awesome if I could set different settings for each motion detection zone.
So for instance, I have the flood light camera above my garage. I would love to set one motion zone at the entrance of my driveway and a little bit on the street. I want the camera to record but not send an alert. Then another motion detection zone from the front of my garage to the front edge of my driveway. If motion hits this zone, I want it to record and send an alert. Then set one more motion zone right in front of the garage door. If we are not home or at night, if motion is detected then the camera records, sends a notification and the sounds the alarm.
Hi @Jake33!
Thank you for your kind suggestions for the eufy Cams.
Your suggestions are valuable to us! It’s a great idea to make eufy Cams more customizable like you’ve mentioned!
I will definitely forward these ideas to our support team.
Best regards,
Anker community team
