Deal of the Day! | Awesome UK deals! (Cable, Charger and Battery)
(20% OFF) PowerPort 4 Lite
Regular Price: £11.99
Deal Price:£9.59
Valid region: UK
Valid Time: September 18th
https://www.amazon.co.uk/dp/B01MXXOQTE
(20% OFF) PowerLine+ Lightning Cable (6ft)
Regular Price: £10.99
Deal Price:£8.79
Valid region: UK
https://www.amazon.co.uk/dp/B0177NSA9A (Red)
Regular Price: £12.99
Deal Price:£10.39
Valid region: UK
https://www.amazon.co.uk/dp/B0177NZ59S (Gray)
https://www.amazon.co.uk/dp/B0177MVBFG (White)
https://www.amazon.co.uk/dp/B0177OAB3W (Gold)
(20% OFF) PowerCore II Slim 10000
Regular Price: £25.99
Deal Price:£20.79
Valid region: UK
https://www.amazon.co.uk/gp/product/B01NBQX0O5
Thanks for th the discount.
Can you please modify the 4 Lite product to add a USA type plug to the existing UK and EU type. You can do that either via making a fold out USA pins which when folded in then you slide on an adapter, or add a USA type plug to the existing design
Lovely the pund is quite low right now!
Think i’m buying there
I wouldn’t mind seeing a future revision of the ‘Fusion’ using the PowerPort lite approach to wall plugs…
Thanks Nigel, your suggestion have been added to our product suggestion form from our customers, hope your idea will be adopted by our product development!:blush:
If you modified the USA folding pins recess across the Fusion, Powerport2,4, to then slot on a EU or UK adapter then you’d have overall the lowest cost.
that could be cool in spain too
