Pros :
very good cleaning performance
replaceable battery
LEDs on the brush head
removable dust container
large scope of supply
Cons:
Partly big quality defects
Position of the Circuit breaker
Trigger must be pressed permanently
Pros :
replaceable battery
Cons:
Thanks for the translation!
I translated only the pros and cons to give a first impression.
Seems they are honest.
Many others are not, but this doesn’t help the company.
More translation can be done by an translator.
