Hi Anker
Just bought a new Ipad pro 2020, but the cable is too short an doesn’t fit in my Anker charger. (usb c) Which cable do you recommend
Hi Anker
Here is one
Thanks for the answer, but my charger is USB-A, so it must be USB-A to USB-C
Check this one instead
