Just bought an ANKER mini speaker. Need to know if I can give it an initial charge using a power bank
Will the voltages be compatible?.
Charging my ANKER bluetooth mini speaker
Charging via a power bank will be fine, the speaker will only draw the maximum volts/amps it needs…
Thanks Don’t want to damage it before I get started.
Is there an on line manual about this product. I`m having trouble understanding the instructions.?
How long does it take to charge?.
Is is the Mini or Mini 2?
Both should be available under the downloads section of their product pages;
