Can Nebula Capsule be charged with Anker PowerPort?
I had an Anker PowerPort 2 Ports years ago, can I use it to charge Nebula Capsule instead the included charger without any problem?
@sendtovuha Yes you will be find to use the charger, it will only output the maximum amps of which the receiving device can takeā€¦
Thank you so much, the charger is working even with maximum ~2A output
