Buying Guide: Anker Wall / Desktop Chargers!
Hi! If you’re looking into purchasing one of Anker’s USB wall/desktop chargers, but aren’t sure which one would be the best for your devices, hopefully this guide will help you out.
My goal is to prevent you from becoming like this person because I truly do believe that Anker makes better products, so, without any further ado, let’s get started!
The most important factor that should go into deciding which charger to get is what devices you’re planning on charging with the product.
-iPhones/iPads, Quick Charge compatible devices (most Android phones), or USB-C devices?
Then, you want to start thinking about how many devices you could potentially have to charge at once (how many ports you’ll be needing). Finally, do you want a wall charger (one that plugs directly into the outlet), or a “desktop charger,” as Anker calls them, which simply means that there is a cord that runs from the outlet to the charging hub itself. These are present on the chargers with more ports.
If iPhone/iPad only, then you might want to consider one of the following chargers.
-2 port (wall)
-4 port (wall)
-5 port (desktop)
-6 port (desktop)
-10 port (desktop)
Another innovative Anker product is their PowerCore Fusion, which serves as a hybrid between a wall charger and a portable charger. Check it out!
*Note that all of these chargers are also compatible with Android devices. They just might not charge as fast as their full potential.
With that being said, if you’re going to be charging one or more Android devices, then I’d strongly recommend the following chargers:
-2 port (both are QC, wall)
-4 port (only 1 is QC, wall)
-5 port (2 are QC, desktop)
*Note that these chargers are also compatible with iPhones and iPads.
If you have a device that uses USB-C, then your options are very limited ATTM, but here are a couple of the best ones:
-1 port (wall, can charge a MacBook at full speed)
Cheaper alternative: 5 port (only 1 is USB-C, desktop, can NOT charge a MacBook at full speed)
*Note that you can also charge USB-C devices with via a USB-A port. It might not be full speed, but all you need is a USB-A to USB-C cable.
Keep in mind that the more ports the charger has, generally speaking, the larger and heavier (and less portable) the charger is.
I will keep the information in this post updated as new products become available.
I hope this information helped you choose which charger to buy! Let me know if you have any questions or share your experience with Anker chargers! Thank you and have a nice day!
Please check out my other buying guide for car chargers!
Thanks for putting this together.
I find after knowing what type+quantity of devices to charge, I next decide if the I want a charger to have the pins built-in or it is corded and the pins on the end of a standard cord. That relates to distance to the wall socket. I travel a lot on business trips and this flips me between the 5 port type (with cord) and the 4 port type (no cord). I pair the no-cord (say 4 port) with a 12ft extension cord. In general, the less I know about the destination the more I got with the no-cord method as it will cover me for unknown and potentially long distances to wall sockets. Extension cables can take 3 chargers so a 4 port + other is plenty of sockets.
Great post. Very helpful for those that are undecided and confused on which to choose. :slight_smile:
Good post :thumbsup:
Nice post… Will definitely contribute to helping people decide on wall chargers…Without all the extra lingo
I updated the post to reflect that thinking! That was a good idea. Thanks!
I might take some photos to help your guide.
What other pictures would you recommend I insert? Thanks!
if you are staying home, vs if you are traveling, and how you travel, impacts what is the best answer. I spent sometimes weeks moving out of a backpack and I may walk 100 miles, so I have the weight of the Anker items, all of its cables, plus their size impact the size of the backpack and the backpack’s weight. Can show size+weight of different chargers+cables.
Shorter USB cables vs longer power cord = electrically more efficient and lower cost. Why have say a 5 port desktop charger with a short power cord and long USB cords, when a longer powercord and shorter USB is lower cost and more power efficient.
Photos would show this better than words.
Here are some size comparisons of different options.
Shown is:
  • Aukey 12W dual-port charger
  • Anker 24W dual-port Powerport2 (not the Elite)
  • Anker 40W 4-port Powerport4
  • Anker 40W 5-port Powerport5 USB-C
  • 12ft extension cord
Example of using the 12ft extension with the Powerport2 and Powerport4 to make 6 ports of 64W combined. The extension cord can plug in 3 items at once but the Powerport block a port so its 1 each side to make max 2 connected.
If:
  • the wall socket is near by your devices (e.g. desk socket) then the smallest simplest are the Aukey (if need 12w / 2 sockets), Powerport2 (24W / 2 sockets), Powerport4 (40W / 4 sockets) as they are simple devices with folding pins and in this context you need short USB cables, so overall a small simple package.
    Else if:
  • the wall socket is a few week away, the Powerport5 (and hence the 6 and 10 port bigger versions) are the next simplest, you have the supplied 5ft cord to the wall socket and then the Powerport is next to your devices, also on short USB cables
    Else if:
  • the wall socket is far away, say 10ft away, then use the extension cord to get it like as per right next to you, then use the 2-4 port, in combination to get the ports and Watts you need.
When I travel to an unknown location, I take the 12ft extension cord as it allows for maximum flexibility, then depending on how many devices I have, the required port capacity from the individual chargers. A common one for me is the Powerport2 and the Aukey as then 4 ports 36W to charge phone+tablet+powercore+BT.
If you did want to combine a Powerport charger with some stored power then shown is the Powercore Fusion 5000 (the black one in middle) which is a combination of a 10.5W 2 port charger with 5000mah of energy, among the others.
g
Lingo just means…All the extra verbage…Over wording, …You’ve broken it down to something the average user might be able to understand a lil easier. :grinning:
@nigelhealy I don’t think you have enough. Better get some more :stuck_out_tongue:
Thanks Josh, we will always support good post in the community, good job!:heart_eyes:
a great post. I have many friends who ask me what type of charger to buy. This article solves the problem.
thanks Anker.
Thank you!
October 2017 Update:
Hi, if you’re looking into purchasing one of Anker’s USB wall/desktop chargers, but aren’t sure which one would be the best for your devices, hopefully this guide will help you out!
-iPhones/iPads, Quick Charge compatible devices (some Android phones), or USB-C devices?
-2 port (wall)
-4 port (wall)
-6 port (desktop)
-10 port (desktop)
*Note that all of these chargers are also compatible with most Android devices (for specific exceptions see Amazon listings). They just might not charge as fast as their full potential.
With that being said, if you’re going to be charging one or more Qualcomm Quick Charge compatible devices, then I’d strongly recommend the following chargers:
-1 port (wall, PD)
-5 port (desktop, only one is USB-C, which is PD)
*Note that you can also charge USB-C devices via a USB-A port. It might not be full speed, but all you need is a USB-A to USB-C cable.
Keep in mind that the more ports the charger has, generally speaking, the larger and heavier (and therefore less portable) the charger is.
I will try my best to keep the information in this post updated as new products become available.
I hope this guide helped you choose which charger to buy! Let me know if you have any questions or share your experience with Anker chargers! Thank you and have a nice day!
what about powecores, Especially powercore + 20100 usb c
I was going to make a guide for power banks, but I was far too confused myself to make any valid recommendations, and as often as Anker releases new ones, it is hardly worth it. Here is an example of all the 20000mAh power banks Anker sells on Amazon right now.
PowerCore 20000
PowerCore+ 20000
PowerCore II 20000
PowerCore Elite 20000
PowerCore Speed 20000
PowerCore Speed 20000 (Upgraded)
The situation with the 10000s is better, but only slightly.
PowerCore 10000
PowerCore+ 10000
PowerCore II 10000
PowerCore II Slim 10000
PowerCore Speed 10000
PowerCore 10000 QC
Perhaps the saddest part is that out of all I listed, none have USB-C. It is almost 2018. Surely @nigelhealy is also disappointed. I thought they ‘promised’ more!
@joshuad11 I am sorry I meant wall charger to charge a USB-C 20100 the fastest possible way
