Battery replacement
Hi i am using Anker Soundcore liberty 2 pro i want to know how can i replace battery of my buds
I would say its not possible so far.
Or may be you are a super skilled tinkerer.
If you’re asking the question then you don’t have the skills, they are glued closed to make reliable and slow water ingress and the act of opening them will break the plastic. Watch any teardown.
Look it up on youtube
