Hello Apple experts
Question : What is the difference between using the 2 pin white block and the 3 pin gray extension wall cable to charge your Macbook? In terms of time to charge and power consumption?
Thanks
Neil
Apple Macbook Charger cable question
I don’t believe there is a difference (although I’m not an electrical engineer) and if there is it would most likely be a very negligible difference between the two.
