Anker USB-C short cables
This is directed to @AnkerOfficial
When are you releasing 1 foot USB-C to USB-C cables? I searched around within your brand and could not find any. I had to purchase a 2-pack from a competitor. 1 foot is desired for use with my portable power bank. 3 foot cables are not feasible when charging inside a pocket.
I’d like to see an influx of USB-C products from you. Don’t let your competitors grab the market :sweat:
They WONT release a usb-c to A lead in 4", apart from a multi-pack with it included.
So I doubt very much, they’ll release a small usb-c to usb-c lead by itself.
Do you know for sure that aren’t going to make some?
I would like to see some from Anker as well, I like them for less clutter on a desk when I’m using a battery bank.
They’ve told me… We won’t be making the 4" USBC available outside of the multiple cable pack.
They say it’s too expensive to make USBC short lead, and a usb-c to usb-c is even more expensive to make, so I’m as sure as I can be.
The new standard is USB-C. Many different Android devices are using it. It’s fast, efficient and easy to insert.
Doesn’t make sense to deny Type C Android users that are here and are rapidly growing. Competitors are making the cables. I’m asking Anker to continue to dominate the USB cable market and don’t let USB-C slip away. Simple as that.
Hopefully @AnkerOfficial can verify that they aren’t going to make shorter USB-C to C cables.
There is no plan for Anker to make 1 feet USB-C to USB-C cable currently. But trust me, the 3 feet one wouldn’t be a bad choice.:grin:
More people want a 1ft/½ft cables than want 3ft.
The short cables are NEEDED for pocket charging.
People will pay upto £6 (GBP) for a decent CHARGING cable/lead.
We need… 4"/½ft length, 6ft, 10ft
I think most buyers if asked about getting a 3.3ft lead, will say they wanted it smaller for charging on the go… Do a.poll.
Thanks that’s some good info to know :slight_smile:
I did tell ya!
True, but it’s nice having it verified rather than just being told “they told me”.
I agree with doing a poll. Find out what your customers want @AnkerOfficial
1 foot cables have always been around for Micro USB and Lightning. USB-C should be next, presently since Anker sells USB-C power banks and again, USB-C is the new standard.
I agree. I usually work on a desk, or a table with my MacBook, or my play with my switch connected to a battery bank, and I like less cable to be sprawled out.
I’m currently just zip tieing my cables to make them pretty much 1 foot.
Same here, and in my pocket. Ever have a cable get caught while walking outside? Not good on the device as it can come crashing down.
