Usually I will only putting in my earbud into charging case when battery depletes to low level like 20%. For this earbud, does anyone know how to check the earbud is fully charged without taking out from the case? Is there any light indication?
Anker Soundcore Spirit X2 Charging
Hi @max_min90 there is not battery indicator on the earbuds themselves, only the case to help determine its own charge level. You would need to remove the earbud from the case and use the battery widget of your phone to find the current battery state.
Thank you man…Clear for me…
