Hi,
Love the sound from my new anker soundcore! Buuut, when I pair it with my phone (android, OnePlus2) the speaker often skips, blips in and out and I have no idea why. Any ideas? (My phone is right next to the speaker and it still does it.)
Hi,
Hi @kitkat , have you tried forgetting and pairing your phone again? If this fails to resolve do you have access to another BT device to rule out a compatibility issue with the phone / version of Android OS?
Should either of these fail to help you would be best contacting support@anker.com with your troubleshooting steps taken, SoundCore serial and purchase date for further assistance.
I would test the soundcore with another phone and see if the soundcore behave similarly.
There are some reports of bluetooth issues with the oneplus 2
https://recomhub.com/blog/problems-with-oneplus-2-bluetooth/
https://forums.oneplus.net/threads/solution-skips-dropouts-fast-audio-over-bluetooth.309254/
You could also try connecting the headphone jack to the aux port on the speaker if it has one.
Hello
I, too, love the Soundcore!
I have what sounds like the same problem and Iāve just contacted Support to find out what to do. I listen to Classical music on my speaker, and it seems to happen when the music is quiet. I wonder if the speaker āblips outā when it canāt detect music, and blips back in when it can?
Iām using a Lumia 950, a Windows Tablet and a Windows Laptop - same problem with all three, and no problem with my other Bluetooth speaker setups around the house and car.
I will post further when I hear from the Support people.
Hello again!
The support people simply sent me a new speaker. Alas, the problem remains - the new speaker shows the same symptoms.
Seems I am having similar issue with speakerphone. I do not see the B.T. signal dropping, only the sound. Need to understand if this can be fixed or I am going to have to return. I spend too much of my day on conference calls via Teams or Zoom to not have a reliable conference speaker
Delete the speaker from the bt list of that phone and do a new pairing.
Does the speaker pair via bt with another device?
