My car is having electrical issues and therefore the speakers aren’t working, I want to replace them with a Bluetooth speaker, that can compare in sound and audio quality, would the Anker Soundcore Motion+ be a good fit? Honestly I mostly want it to be loud to be able to thrash my head to some good music while driving. (Safely of course)
Anker Soundcore Motion+ - Replace car stereo
If you want to replace stereo, you would need 2 speakers.
The motion + is good speaker I think if you use two of these it could do.
Motion+ should be ok, but it is not a complete replacement for the car stereo system. Music on these feels good.
Try to go with 2 Motion+ for Stereo Pairing.
If looking for more economic options, you could use Flare / Flare mini Pairs (Stereo Pairing)
I’d recommend the Soundcore Trance
I tested using Soundcore Flare 2 in my car couple of weeks back while on vacation… that was great…
have to test the Rave mini one of these days on the car
Mini party bus!
Love it Franz, it’s hits you
If its like the UK one…be careful on the reverse
Lol he didn’t he wanted some loud
