Hi,
I just purchased the Anker SoundCore mini - and it’s very impressive.
I wanted this exact device to have as a simple small player for my elderly father. I have saved all his favourite CDs onto an SD card. However, I can’t find a way to have the speaker automatically default to the SD Card to play once the speaker is turned On.
It seems the only way so far is to remove and the insert the SD Card and then it plays fine (even if the default sound is also too loud).
Are there any hints as to how to make the speaker default to the inserted SD Card?
Otherwise, the speaker is amazing quality and features.
Thanks
