All I will say is that Sport XL is closer than you may think…
Please watch my full video review on YouTube!
Quick Side Note: I filmed and edited this with my iPhone 6! I wouldn’t call it fun.
Odd for the price doesn’t include audio cable.
Seems to me like the smaller, older ones do, here as the newer, larger, and more expensive ones don’t.
just odd that if you have a higher cost BT speaker you’d only use BT when you cannot have a physical connection, a cable is always better audio quality to BT, less need for compression. Does the Pro include audio cable?
Sure doesn’t.
I can second that. The pro does NOT come with aux cable.
Nice review Josh, audio quality certainly seems close on the two. What volume percent were you doing your test on?
Weird that they have dropped the aux cable, especially with the price boost, that sort of behaviour I expect from Apple
Great review Josh Getting tempted to buy a boost here…
Also impressive that you put the video together on an iPhone!
Nice review @joshuad11!
80% but then lowered to 50, so ended up being 40.
No kidding. I also have a MacBook Air, but was up for the challenge. I think I’ll be investing in a 10.5 inch iPad Pro soon.
