Anker Roav Jump Starter Pro 1000A, 12800mAh Powerful and Portable For $75.99
Anker Roav Jump Starter Pro 1000A, 12800mAh​
Powerful and Portable For $75.99 with $20 Amazon and code ROAV33RR
jump starter pro 1000A
Roav, by Anker Innovations, is dedicated to creating connected devices for your car that improve the convenience, safety, and enjoyment of every drive.
Hit the road without a worry with Roav’s most powerful jump starter. With a 1,000A peak output capable of jumping engines up to 6.0L, an emergency LED light, and 3 USB charging ports, have the power to handle any emergency while on the road.
  • Jump 6.0L Gas or 4.0L Diesel Engines
  • Emergency LED Flashlight
  • 12,800mAh Battery Capacity
  • 3 USB Charging Ports
  • Compact Design
Key Features
Brimming with Power
Jump start your car up to 20 times from a single charge.
Keeping Things Cool
A built-in sensor detects the operating temperature, cutting off power to prevent overheating.
Safety First
Premium components ensure you can safely jump start your car. Operating temperature between 0–60°C.
Key Features
Triple-Port Charging
Keep your phone charged in an emergency with the 1 USB-C and 2 USB-A ports.
Monitor Your Battery
Attach the clamps to your car battery to keep an eye on its status via the easy-to-read screen.
DC Output
Deliver a boost of emergency DC power to any compatible car-mounted appliance (DC cable not included).
Description
Road Jump Starter Pro 1000APowerful 2-in-1 Jump Starter for Heavy-Duty Engine sit’s Quick and Easy There’s no need to bother your partner, friends, or the local roadside assistance when disaster strikes. Simply open, clamp, and jump to get yourself back on the road, all on your own. Small Size, Immense Power Capable of fitting inside your car’s glove box, this compact 12800mAh jump starter can deliver enough power to restart a 6.0L gas engine or 4.0L diesel engine. Get up to 20 jumps from a single charge. More Than Just a Jump Starter Be prepared in case of an emergency. The powerful built-in LED flashlight illuminates your engine bay for efficient jump starting in any conditions. Instant Check-Up With an easy-to-read LCD screen built into the jump clamps, instantly learn the status of your car’s battery. Super Charger3 USB ports with Power deliver a boost of power to your phone, tablet and more, ensuring your devices are ready for action in case of emergency.
Features & details
  • Powerful and Portable: Jump start your vehicle up to 20 times on a single charge. Compatible with gas engines up to 6. 0L and diesel engines up to 4. 0L.
  • Superior Safety: Premium copper clamps and advanced safety features work together to keep you safe while jump starting your vehicle.
  • Emergency Charging: A 12800mAh battery combined with Anker’s fast charging technology delivers an emergency boost of power for phones, tablets, and more.
  • S. O. S Lighting: Attract attention or illuminate your engine bay when jump starting at night with the integrated LED flashlight.
  • What’s in the Box: Road Jump Starter Pro 1000A, jumper cable with clamps, carry case, protective recharging and storage bag (charger NOT included; a 5V/3A adapter or car charger is recommended), our worry-free 12-month , and friendly customer service.
