Anker red powerbank
But thank you I really appreciate it.
So basically there is only two types of red portable charges by anker
There’s also this one, but I’m sure it doesn’t ship there either.
Don’t know why they don’t ship.
And there used to be one called PowerCore Slim 5000 and Astro E1, but I believe they’ve both been discontinued.
Which is do you think is worth it
The one I just posted — PowerCore III Sense 10K — is the only one I’d currently buy.
Thank you for sharing your opinion I’ll take it into consideration.
No problem!
I’ve checked it out and honestly I didn’t like the material
Which one are you using?
Which one do you recommend?
Yeah, it’s definitely different, but in terms of specs, it’s the only one I fully recommend.
I use the powercore fusion 5000 everyday for headphones, speakers, my phone, etc. It does all I need and more. But as a powerbank it is only 5000mah so the average phone these days will only get one charge from it. If you want just a powerbank there are definitely better options, but as a hybrid charger it is pretty awesome.
I’m using the power cord 10400 it’s really good but looking for an upgrade
Hey @Jad.sahmarani
You’re limiting your choices if you only want red.
I concur with @Insider with the PowerCore III Sense.
Although not red, the best PowerCore I’ve experienced is;
Which one did you decide on?
I couldn’t get my hands on none of them :disappointed:
None of the red products can be shipped to my country. I’ll stick with black and white ones
Here’s the red PowerCore III Sense 10K on Amazon:
