Hi all! I’m located in the US and I purchased the PowerCore Speed 20000 PD (Power Delivery) with the Anker 30W Power delivery brick/bundle. I am planning to use the PowerCore while I am traveling overseas with my MacBook 12" (Retina). However, the potential places I would like to go obviously do not use US 110v plugs so I cant use the Anker brick. I’ve purchased the travel adapter plug kit from Apple to use with my MacBook brick. Would I be able to use my MacBook brick (45W I believe) with Euro/220plug to charge the PowerCore at full speed? Thanks in advance!
Anker PowerCore Speed 20000 PD Charging with MacBook Brick
Yes, that should work. However, the PD spec is still fairly new so exact incompatibilities may still be unknown.
Yep it works I use my mbp charger for the 20000 pd works really well.
Check, usually with a magnifying glass, the Power specs written on the wall charger. It is almost certainly a 110V-240V autosensing input, if it is then you need only to alter the pin shape via a dumb adapter that cost $5 typically.
