My Anker PowerCore 26800 does not charge anymore. According to the descriptions, I can connect 2 adapters of 5 volts with 2 ampere together for a charge of 6 hours.
I did this, however, the PowerCore charged up till 50%, suddenly all the LEDs went off (less than 2 hours of charging time).
If I re-connect 1 adapter to charge the PowerCore (1 x 5 volts and 2 ampere), the first LED will flash briefly, and rapidly every LED went off.
When no cable is attached to the PowerCore, and pressing the button at the side of the PowerCore, no LED on the PowerCore gives an indication of the capacity anymore.
Is there a given solution for this problem? I’ve already contact de seller, because I think the PowerCore is broken.
Model number: A1277
