How long should you charger your portable charger for and dose it matter if you over charger it ?
Anker charger time for the 26000mah portable charger
What are you using to charge your Anker? Your charger should automatically cut off when the Anker is fully charged. The Anker itself will prevent over-charging but keeping it always at 100℅ charge for a long time probably isn’t good for it.
There are a few 26800 portable chargers.
The most recently released is a dual 2A input so 4A input. So the 26000mah = 26Ah / 4A = 6.5 hours but it will trickle charge as it approaches 100% charge so I’d expect fully flat to charged in about 7-8 hours.
If you used one 2A input to that battery then 13 hours and add a bit for trickle charge towards end so say 13.5-14 hours.
You can do the same math on knowing what is your input from your usb charger to your portable charger.
