Let there be light!!!
The torch was delivered very quickly (AMAZON)
The wrapping is appropriate, the product is excellent (ANKER)
The package contains the torch (including the 3350 battery) a cable USB -> USB-micro and a instruction sheet
The torch is made of aluminum
Really very tough.
The charging socket (USB micro) is locked watertight.
I think the torch will not be affected by a little downpour.
(according to ANKER IP65 water resistant)
And a little fall will do no harm.
Ergo: Absolutely suitable for outdoor activities.
The torch is equipped with a battery which can be charged by the added cable (USB -> USB micro)
(Indicator : red charging, blue fully charged)
The clip to clamp the torch at a rucksack or a bike is very useful.
The torch has 6 switching modes
ON & OFF (By pressing the button for 2-3 seconds the torch will be switched off and not be switched through the modes)
3 brightness levels (400,120,20 lumen) (corresponding battery power of 6, 20, 50n hours)
1 Flash
1 SOS
A well-thought-out specification indeed.
These modes can be switched logically by the waterproofed button.
This button is mounted in such a way, it is not possible to switch on the torch accidentally when stowed in a rucksack or something like this.
For a long-term outdoor use I recommend taking along a power bank (ANKER )
So light will NEVER be switched off.
Very important : dimensions and weight.
The torch weights 122 grams ( 4,3 oz )
The torch has a length of 12,5 cm ( 5" )
The head of the torch has a diameter of 3 cm ( 1,18" )
Really small and very handy. Perfect to plug in the jacket.
Caution: Don’t blind your or other’s eyes with the torch!
Conclusion:
Though not inexpensive, this very good, tough torch is worth the price payed for.
It stands out against those many offered low-price products by its high value.
And last not least : ANKER offers an unbeatable customer-friendly service!
Sorry, English is not my mother tongue, so there might be some errors.
Addendum : If it is possible to design such a torch including a power bank inside, this would be very innovative!
As I told before, English is not my mother tongue, so there might be some errors.
