Anker Aluminium USB C to HDMI Adapter not working on Macbook Pro 2017
Hello together,
I bought the Anker Aluminium USB C to HDMI Adapter at Amazon (http://amzn.to/2mOX0rS) to connect my MacBook Pro 2017 to an external HDMI Display.
The external display(s) will not be recognized!
I tried two different displays with different HDMI cables. Also I tried to reboot and different connections at the Mac - nothing.
Please help!!
Sound likes a possibly defective adapter. You could try changing the screen resolution of your Macbook to see if it gives the external display a kick into action but failing that I would suggest you drop an email to support@anker.com with your serial, purchase date and troubleshooting steps taken for assistance under your 18 month warranty.
Thank you for your response.
Changing the resolution did not lead to success.
I will fix it by Amazon.
  • close
Regards,
Thomas
Unfortunately all new MacBooks (usb c) don’t work well with third party adaptors.
I think it’s an apple side problem, I never had problems with Anker stuff, but with my new MacBook 15 with touch bar it’s a very annoying thing.
I tried a lot of adaptors and Hub but no ones work well.
