Just received the Anker 500ml diffuser…so excited to try it out, unboxing was a breeze, as with all the products from Anker…filled up the tank w/ under 500ml of distilled water, added my essential oil, and plugged it up.
Problem I’m having is once I press “Mist”, the machine beeps, and less than 2 seconds later it beeps again and shuts off.
The light works with the changing colors…the problem again is when I press “mist” it shuts right off.
Pretty upset as I’ve got everything set up and it looks as though I’ve got a bad unit, and will have to dump the water w/ oil (What a waste !).
Can’t contact support until Monday, wondering if anyone else has had this trouble before.
Not a great start and my excitement is now disappointment and frustration.
- MJ76
