- The dynamic driver needs rear venting. This is very important.
- Bass response will be more controllable.
- Bass response will be more accurate
- Eliminate potential driver flex
- Reduce risk of hearing damage
- Improve soundstage.
- Minimal increase in sound leakage
- Include a custom parametric EQ in the Soundcore app with user selected frequency ranges and Q values.
- Even with Bass Reducer preset there is an exaggerated midbass hump that bleeds over midrange sounds like guitars.
- Allow users to tune to their exact preference.
- Will add value to all other Soundcore or other Anker products.
- Make the nozzle longer or include tips with longer nozzles for deeper insertion.
- The body of the IEM is too large and will not insert far enough to get a seal with the short nozzle in many ears.
A method of volume control without using host device.
Ambient listening mode using microphones.
Allow updating via connecting one earbud at a time.
- Not all devices will recognize each earpiece as separate devices and if you don’t have one you are unable to update your product! As far as I can tell.
