[EXPIRED] 2-Pack Anker GlassGuard Tempered Glass Screen Protectors For $2.99 ( regular $9.99)
2-Pack Anker GlassGuard Tempered Glass Screen Protectors for $2.99 with code GLASP299
Available options:
2-Pack iPhone XR / 11
2-Pack iPhone Xs Max / 11 Pro Max
Product description
Frequently Asked Questions
  1. Why is the screen protector smaller than my iPhone’s screen?
Due to the iPhone’s curved edges, the screen protector is designed to be smaller than the actual screen to prevent bubbling and peeling at the edges. This also allows the screen protector to be used with most phone cases.
  1. Does the screen protector show fingerprints?
Because of the oleophobic coating on our screen protectors, fingerprints won’t stick and can be easily wiped away. We recommend using a microfiber cloth for quick and easy cleaning.
  1. Does the screen protector affect sensitivity or the 3D Touch function?
No, it won’t affect the touch sensitivity or 3D Touch function since the screen protector is only 0.3 mm thick.
  1. How do I ensure a successful installation with less bubbles and dust?
Clean the frame with the alcohol wipe before you align it on the screen. For best results, apply the screen protector in a clean, dust-free environment.
  1. How should I remove bubbles?
Before installing the screen protector, clean the screen according to the instructions included in the packaging. If large bubbles still appear, lift the screen protector to eliminate them, then place the protector back in position. If small bubbles appear, press them with the squeeze card for around 1 minute.
Features & details
  • Double Defence Technology: 9H-hardness tempered glass has twice the strength of alternatives for superior defence against scratches.
  • Highly-Responsive: At only 0.33 mm thick, 94% of light is able to penetrate the screen protector—maintaining the original touch and viewing experience.
  • Oleophobic Coating: Reduces fingerprints and smudges to keep your screen pristine.
  • Easy Installation: Use the alignment frame for a perfectly positioned, bubble-free installation.
Good find Shenoy = Sherlock! :rofl:
One of my essential buys when I’m getting a new phone (or case)…nice find @Shenoy!
Lay the screen protector carefully on the phone screen will be a challenge for me…
Thank you @Chiquinho :male_detective:
@ndalby it a good decision :+1:
I have been using Anker Glassguards for all my phone models starting from iPhone 5 till iPhone X… and this has saved me a lot of money, had multiple falls, where the this protected my iPhone … would say, this is a must for any new phone purchased
@AnkerOfficial This has never been a challenge for me, there will be 2-3 air bubbles but these usually go away in 4-5 hours… magically!
Great deal, thanks for sharing !
Nice deal, thanks for sharing!
Great price for 2 screen protectors!
Awesome price. Now, I just need the phones :stuck_out_tongue:
I always have some issue when I install a new screen protector.
Nice deal!!! :ok_hand:
It comes with a guide though!!
I’m ordering these right now
Grrrrhh it’s not available anymore. So aggravating
These usually expire quickly, with new iPhones being released, these are already selling hot.
Trick is to apply these in low-dust area, having hot steam removing all the dust in the area before applying the GlassGuard, run hot shower in bath room removes all dust, then follow the steps per the guide, clean the phone screen using the alcohol wipe, and then clean it, apply the screen with orientation …
Do you know why japanese lacquerware is so perfect?
The artists went out on the sea and worked there.
In China, I usually pay 5 yuan to ask someone install a new screen protector for me…:joy:
Hope this 5 Yuan includes the sea voyage I mentioned regarding lacquer works! :rofl:
